2000 Silverado Missing When First Started
Old Feb 10, 2017 | 12:44 PM
chevysilverado2000's Avatar
Default 2000 Silverado Missing When First Started
I have a 2000 Chevy Silverado Extended Cab 4x4 and when you first start it it starts missing and when you press the gas pedal the motor will cut out . You can drive it down the road and the motor will finally start running the way it's suppose to . But if you cut it off it will start doing the same thing all over again. I have put a new fuel pump and new fuel filter on it but still the same thing. Does anyone have any ideas what it might be?
Old Sep 2, 2017 | 1:33 AM
rkent's Avatar
I'm not sure if you got this figured out yet, but it seems I had the same issue. When I first started my truck, it would run rough, miss firing a bunch, until it got warmed up. The colder it was in the morning, the worse is ran. I found that I had a vacuum leak due to the intake manifold gasket. Air would leak in until the engine got warm enough for the gasket to expand and seal up. I hope this helps some.
