2001 Chevy Silverado rear suspension problems
Old Aug 19, 2020 | 4:54 PM
Michael Pereira's Avatar
Default 2001 Chevy Silverado rear suspension problems
Hi! I don’t know much about cars so any help is appreciated. My 01 Silverado single cab has some suspension issues in the rear. I recently had the whole front end suspension replaced as well as the rear shocks. The problem now is the truck has had some aftermarket air bags installed In the rear to help with towing But they are now popped. I don’t tow anything with the truck so my question is do I need to replace the bags or can I simply take them out along with the bump stop piece that’s causing the ride to be really rough? Or can I install some springs in the rear instead? I have access to a 2001 Chevy suburban that I can grab the rear springs off if need be. Thanks for any help!
Bump stop in middle, air bag in top left
New rear shocks
Air bag
Air bag
Old Aug 20, 2020 | 12:21 AM
how about a picture of what's going on?
Old Aug 20, 2020 | 11:51 AM
Gumby22's Avatar
As long as the mounts for the leaf springs are still there (2 on the frame, 1 on the axle per side), there’s no issue in swapping back to springs; however, if it were me, I’d just get new springs rather than used (unless the used ones didn’t have a lot of miles/hauling on them). I don’t see the point in going through the project just to put used springs on that may be worn out.
If the axle mounts were removed or modified, you can get replacement brackets that can be welded on.
Old Aug 20, 2020 | 2:20 PM
Default Just attached pictures
Thanks for the comments already. Just attached pics to the problem. Can I take out the air bags and bump stops since I have shocks and leaf springs?
Old Aug 20, 2020 | 4:54 PM
Default Update: fixed
Just removed the airbags and bump stops and rides smooth now. Thanks all!
epicazo79
Jun 6, 2019 11:45 PM
charlesAL
Feb 19, 2018 6:07 PM
LMacdonald
Apr 30, 2014 9:09 PM
trainwreck91
Jun 7, 2013 3:55 PM
shonoff83
Mar 21, 2013 8:43 AM
