2001 silverado wont start first crank
Old Mar 23, 2019 | 2:48 PM
  #11
Irish_alley's Avatar
I'm here for the party
i know on the tbi trucks the OSP would override the fuel pump relay after oil psi reached 3psi. the OPS is only meant to be a backup for when the relay would fail. i didnt know the 96+ still used this method and not sure they did but sure does sound like it. can anyone confirm?
Old Dec 11, 2023 | 7:27 AM
  #12
Player One's Avatar
Originally Posted by oldchevy
It is more likely that the check valve in the fuel pump assembly is bad. My truck did the same thing and I added an inline check valve in the fuel line near the fuel tank and that solved my problem. i bought the check valve on Ebay and I needed some fuel injected rated fuel line and some hose clamps. Total cost was about $15.00 and I did the installation.
Shot in the dark since this is an old post but this is what I am trying to do and figure the best way, I was thinking to splice in a check valve with ****** ends into the nylon tubing coming from the tank.
However did u just use fuel hose with the valve and hose clamped the valve and then at the pump and where it connects to the hard line.
fitzpatrick44
Jun 8, 2015 8:02 PM
supersport1220
Dec 28, 2013 8:14 AM
advcomps
Sep 18, 2013 10:22 AM
rickgaio
Apr 14, 2013 6:01 PM
hondalover
Feb 1, 2011 4:06 PM
