2003 2500HD BCM issue
Old Aug 10, 2024 | 2:33 PM
Djt65's Avatar
Default 2003 2500HD BCM issue
I have a 2003 2500HD Siverado reg cab base model, 2 wheel drive, 6L engine. I had the BCM go out. I had it replaced. Then I had to replace the fuse block. When it was programmed, the daytime running lights, interior dome light, instrument cluster dimmer, alternator gauge and my backup rear camera stopped working. I replaced the light switch and nothing changed. The dome light has 6 volts. There is no power at my daytime running lights. The instrument cluster lights are constant on.. I had the try and reprogram the computer. Any suggestions of what or where the issue is?
Old Aug 12, 2024 | 8:57 AM
jfmorris's Avatar
To me it sounds like an issue with the new BCM or fuse block...
Old Aug 13, 2024 | 8:33 PM
Djt65's Avatar
Thanks, any suggestions on where or how to test each? I noticed the backup lights don't work/don't have power either. My mechanic has had the BCM "flashed" at least 2 times, and the computer didn't show any errors. Is there an easy way to test the connections? Thanks
OZ757
Avalanche
Nov 15, 2017 2:23 PM
cfakes
Feb 25, 2017 6:24 AM
slash11
Sep 19, 2015 5:34 PM
Wranglin4Life
Sep 12, 2014 5:47 PM
free outlaw vanners
Jan 26, 2014 12:01 PM
