2003 Chevy Silverado 1500 door handles with locks
Old Jul 23, 2024 | 3:21 PM
Tommy O's Avatar
Question 2003 Chevy Silverado 1500 door handles with locks
I just bought 2003 Chevy Silverado 1500 extended cab, Both exterior door handles are broken. I need to buy new exterior door handles with locks. The ignition keys do not fit the door locks. I thought I found them on E- Bay but they say they only fit 2007 Silverado, so can anyone help me find the right ones to buy?
Old Jul 23, 2024 | 8:38 PM
chem_man's Avatar
15 Year Member
It looks like you need 2 separate components. One the door handle and Two the actual door lock cylinder. Rockauto.com is your friend in this case, Here are two links for you:
https://www.rockauto.com/en/moreinfo...t=1024&jsn=622
https://www.rockauto.com/en/moreinfo...=10007&jsn=639
For repair information go here: https://charm.li/
Good Luck!
Old Jul 23, 2024 | 9:35 PM
jfmorris's Avatar
As another follow up, if the key that cranks the truck doesn't fit the door locks, someone has already changed one of those two components out. A replacement lock cylinder will come with its own key I expect. I am sure someone can rekey them to work with your ignition key, but might cost a bit.
Old Jul 24, 2024 | 2:43 PM
Tommy O's Avatar
Thank You for the information.
Old Jul 25, 2024 | 8:25 AM
frank1's Avatar
Also take the lock for the spare tire and glove box, to lock smith. The key for the glove box, if it has a lock, should be the same as the doors, its is not hard to remove, and can be used to cut new key for doors.
Old Jul 25, 2024 | 2:51 PM
Tommy O's Avatar
Thank You, I will look into that.
Old Jul 28, 2024 | 5:37 PM
vms4evr's Avatar
Veteran: Army
I replaced mine this spring with Dorman replacements I bought off Amazon. Price, fit, all fine. 2006 Silvy 1500. Here are the part #s.
Dorman 77261 Front Driver Side Exterior Door Handle
Dorman 80577 Front Passenger Side Exterior Door Handle
Dorman 77488CD Tailgate Handle
Dorman 76106 Tailgate Handle Bezel
Tommy O
Jul 23, 2024 8:05 PM
ozone42
Mar 8, 2012 12:30 AM
queball727
Apr 7, 2010 8:52 PM
89silverado
Jun 11, 2009 8:57 AM
gphillips2
Jan 6, 2007 4:17 PM
