2003 reduced power
Old Feb 2, 2023 | 4:47 PM
Jd74's Avatar
Default 2003 reduced power
2003 silverado 5.3
keeps going into reduced power
i have changed tps,maf sensor , plugs and wires, throttle body,transmission module,grounded all parts to battery tps,trans mod.,ecm and checked body ground and motor ground nothing has fixed it yet sonetimes it will go a month without doing it and like today 4 times in 25 minutes please help with any suggestions maybe a ecm thankyou for feedback
also changed gas pedal and tac module also i can turn the key off and it goes away
Old Feb 2, 2023 | 7:56 PM
post the codes that are setting in the ECM
Old Feb 3, 2023 | 1:20 PM
Jd74's Avatar
Tech2 the codes are p0210,p0161,p1516,p2135
Old Feb 4, 2023 | 2:21 PM
pm'ed u
Old May 15, 2023 | 3:58 AM
06tahoe's Avatar
Did you ever figure it out? I have the exact same issue and have replaced all the same parts. Mines only showing p2135.
Truckman77
Oct 4, 2021 10:13 AM
Larrycarol
Oct 12, 2018 9:45 AM
rlaqhtjq
May 19, 2016 6:31 AM
rlaqhtjq
May 19, 2016 6:20 AM
Crystal Hunt
HHR
Dec 22, 2015 10:37 PM
