2003 Silverado 1500 Turn Signal Problems w Headlights on
Old Jun 12, 2020 | 11:10 PM
d06h0201's Avatar
Default 2003 Silverado 1500 Turn Signal Problems w Headlights on
All my turn signals, brake lights and everything appears to work fine until the headlights turn on.
At all times, when I press the brake for the first time after startup, the turn signal lights on the cluster come on and stay solid until I let go of the brake then it doesn't happen again.
When the headlights are on, the left turn signal stops working when I press the brake, the right turn signal seems to slow down a bit and I have no reverse lights.
I've replaced the stop switch on the brake pedal and tried a new turn signal relay.
The truck came with a snow plow and has wiring hooked into it..
Any suggestions are appreciated.
Thanks.
Updated: Fixed
The ground connection under the bed that connects to the spare tire holder was completely rusted. I cut the wire, drilled a new hole through the same plate added a connector to the wire, placed a new bolt and no more issues.
Michael Barnes Jr
Aug 18, 2021 12:53 PM
AmericanPatriot
Mar 23, 2020 1:16 AM
fraser jim
Feb 15, 2012 11:23 PM
2006isuzu_i280
Colorado
Dec 13, 2008 8:45 AM
DERROLD
Aug 17, 2007 3:50 AM
