2004 Chevy 2500HD 8.1 6 Speed Clutch function
Old Feb 21, 2020 | 12:11 PM
John McGuire's Avatar
Default 2004 Chevy 2500HD 8.1 6 Speed Clutch function
Hello all, I have 04 2500HD 8.1 6 speed.
Clutch finally burnt out last week, so I ordered some new parts I am in the process of replacing said parts.
I have never done something with a clutch before, but didn't really have the spare funds to take it to a shop.
So I got everything apart, and mounted a brand New Fly wheel, clutch and pressure plate. Used the alignment tool and goes in and pretty, much bottoms out the tool.
Question I have is, the kit came with a new Hydraulic Slave Cylinder, its empty no fluid inside the cylinder.
How do I go about Bleeding the system? And should I pre-fill the slave?
I've included a photo below of the style slave.
Appreciate the help, I am afraid I might be in over my head lol....
Old Feb 21, 2020 | 3:49 PM
kevinkpk's Avatar
Not done one in 35 years, but if you have ever replaced a wheel cylinder, I'd say it's along the same thing. It should have a bleed valve, and of course supply line. I'd get a cheap bleed kit from auto zone, pump fluid into it with the bleed valve open for 3-4 times till it just comes out fluid, then install it. You might have to bleed it after it is installed, but it won't be as difficult as wheel cylinders.
tank1949
1988 - 1998 (GMT400)
Sep 13, 2019 8:36 PM
ZChevyAK
Nov 23, 2013 8:36 PM
davidb
Dec 21, 2008 9:07 AM
bssharp79
May 8, 2008 8:20 PM
63NovaSS
Apr 11, 2007 10:14 PM
