2004 silervado z71 P0120 reduced engine power
Old Oct 15, 2023 | 3:22 PM
04cateyebadboy's Avatar
Default 2004 silervado z71 P0120 reduced engine power
Have 04 cat eye replaced throttle body still have P0120 code also replaced pigtail along with pedal sensor still have code and reduced engine power any help or solution from prior experience
Old Oct 17, 2023 | 9:00 AM
chem_man's Avatar
15 Year Member
The P0120 DTC is telling you that there is a problem with the Throttle/Pedal Position Sensor Circuit 1. It does not tell you that the accelerator pedal sensor or pigtail is bad. You have to troubleshoot the entire circuit in order to determine what the problem is. Trouble Codes RARELY if ever says that a given part is bad. The trouble code tells you that something is wrong with a circuit or a system.
Try reading this for diagnostic information:
https://easyautodiagnostics.com/gm/4...sensor-tests-1
Good Luck!
Old Oct 17, 2023 | 2:08 PM
GM Bulletin
File Type: pdf
RyanInKY
May 20, 2024 6:21 PM
bakeraaron125
Avalanche
Apr 8, 2022 7:39 AM
lilac
Aug 13, 2017 7:05 AM
Crystal Hunt
HHR
Dec 22, 2015 10:37 PM
vivero
Jun 23, 2007 2:38 PM
