2004 Silverado Rear Door Strike Plate bolts
Old Jul 23, 2023 | 10:36 PM
gelaro's Avatar
Default 2004 Silverado Rear Door Strike Plate bolts
I was replacing the strike plate on the passenger side rear door and didn't realize the bolts were not welded to the body so it dropped down. How do I get to them to replace the strike plate? I don't want to disassemble a bunch of stuff I don't have to.
Thanks
Old Jul 24, 2023 | 3:54 AM
chem_man's Avatar
15 Year Member
You could try and remove the sill plate(s) on the body between pillars. If you are lucky, they will be in there.
Good Luck!
Old Aug 3, 2023 | 5:19 PM
silverado 1500 2001's Avatar
idk your situation but if your stuck you might ...
drill a hole, use a magnet go fishing, use a rubber body plug as a nice touch.
Frank Lopchinsky
Aug 30, 2021 5:13 AM
Ronald Johnson
Feb 17, 2019 11:56 AM
artscentereast
Mar 17, 2017 7:52 AM
obeliskgm
Oct 25, 2016 2:18 PM
