2004 Silverado - Speed Guage/Trans Issue
Old Dec 28, 2019 | 7:04 PM
tyrobinson's Avatar
Default 2004 Silverado - Speed Guage/Trans Issue
Hello,
I have multiple error codes on my truck right now. Most of them have been there for about a year and havent caused any issues. Recently my speed gauge started jumping +/- 10-15 mph sometimes causing the transmission to upshift or down shift when it shouldnt. I just changed the speed sensor and it did not fix the problem. When i pulled the old one out it was covered in what looks like a metallic colored grease and had mettle shavings on it which i know is not good. What is the next step i should take?
I am new to the forum and joined after searching for 2 days for a similar issue. All help is greatly appreciated! current error codes below:
Underlined codes are some new ones that i found on the last read when i started having this issue. The rest have been there since shortly after I bought the truck a year ago and have not affected the performance of the truck.
P0174 = Fuel Trim System Lean Bank 2
P0442 = Evaporative Emission (EVAP) system small leak detected
P0724 = Brake Switch Circuit - High Input
B092 = Left side Restraints Sensor 2 (Sublfault)
U1000 = Class 2 Data Link Malfunction
P0101 = Mass Air Flow System Performance (Truck has a cold air intake on it)
Old Dec 28, 2019 | 7:07 PM
tyrobinson's Avatar
I forgot to mention this is a 5.7L 4WD
Bucs2120
Aug 20, 2018 3:16 PM
lbolton64
Apr 19, 2018 12:34 AM
HunterManitoba
Nov 9, 2017 2:42 PM
Tagnamee
Aug 12, 2015 12:09 PM
tonyvisone
Mar 27, 2014 8:33 AM
