2005 Chevrolet Silverado abs brake light on
Old Feb 18, 2020 | 5:36 PM
Mefan's Avatar
Default 2005 Chevrolet Silverado abs brake light on
2005 Chevrolet Silverado abs brake light on .... came on when I put a smaller tire size on when I got a flat. Recently I changed the wheel hub out with a new sencer.. lights still on . Mechanic says it is both the wheel hub and abs module.are bad . I tend to dis agree sence I just changed the wheel sencer. He said there is no signal from the wheel sencer. Can anyone help me figure it out?
Old Feb 19, 2020 | 6:43 AM
Check the wiring to the sensor and the connector to make sure there is a good connection and no damage to the wire as far back as you can check.. Do this on both front wheels.
Old Feb 19, 2020 | 8:55 AM
Mefan's Avatar
Yes I have checked the wires according to the mechanic the code is the rt front sencer but that has been changed
cmsdetailing
Nov 11, 2019 7:44 PM
05 Silverado
12
Oct 25, 2017 2:15 PM
schuey59
Apr 10, 2012 1:38 AM
mjjv
Aug 12, 2008 11:08 PM
hnic
Jun 26, 2006 11:26 AM
