Chevrolet Malibu
abs and handbrake light on
Old Apr 14, 2006 | 8:27 PM
hnic's Avatar
Default abs and handbrake light on
hey guys my handbrake and abs lights comes on and wont go off, while driving a beeping sounds comes on like if the door is opean, can someone tell me whats causing this.
Old Jun 26, 2006 | 11:26 AM
BCKNBLK's Avatar
Default RE: abs and handbrake light on
I have a '99 Malibu, and was having a similar, if not the same problem. The "regular" brake light (red one) was coming on because the brake fluid level sensor went bad. It is mounted under the master cylinder. Really easy to change out and cost is minimal. Coincidentally, at the same time, my ABS (yellow) light was coming on intermittently, then after several days it was on constantly with the chiming noise you described. After doing a GOOD visual check to make sure none of the ABS components were damaged, I changed the hub assembly, which contains all of the ABS components down at the respective wheel. That solved the problem. I ran a quick scan to tell me which wheel was having the problem. Hub cost about $160. Job only took about 3 hours, and that was with a break included. Very easy.
idk2050
Mar 24, 2015 9:32 AM
kaptain howdie
Dec 16, 2014 8:20 PM
ericmckinney
Uplander
Oct 14, 2011 10:35 PM
Bulldog9539@gmail.com
Sep 4, 2011 1:54 AM
Deteoni
Mar 28, 2009 1:39 PM
