2005 Silverado 1500 2wd parking brake adjustment
Old May 19, 2021 | 6:29 PM
javierestrada533's Avatar
Default 2005 Silverado 1500 2wd parking brake adjustment
I have a 2005 Silverado 1500 2wd with rear drum brakes. The cable at the equalizer is loose (the cable that goes to the passenger rear drum, will include image) how should I go about adjusting it from the pedal or the drum?
Old May 19, 2021 | 8:18 PM
you should adjust the drum first... both sides. them with the correct drum clearance adjust the cable if needed.
the cable should rarely need adj ustment. When the drums and shoes are changed...if not set up right ;the ebrake will be loose and the service brakes will have a deep pedal.
something is obviously wrong with your set up...correct cable?
Old May 20, 2021 | 12:50 AM
Its the correct cable.
Old Mar 21, 2024 | 3:57 PM
Dgrav's Avatar
Was this ever fixed? Im having the same issue right now and im not sure what to do
toolhore
Apr 6, 2020 3:33 AM
SpudmanWP
Jun 11, 2015 7:09 AM
wargle
Jul 7, 2014 9:23 PM
bigb
Aug 12, 2013 8:56 PM
Bajabound
Dec 15, 2012 9:07 AM
