2005 silverado starting issues
Old Apr 1, 2017 | 2:27 AM
Garrett Storm Howell's Avatar
Default 2005 silverado starting issues
I have a 2005 Chevy silverado with a 5.3 vortec 4X4 and after it sits for awhile to get cooled down when I go to start the truck I have to hold the key for about 3-5 seconds it cranks over a few times then it starts but when it starts it lowers idle then goes back to normal idle which is around 500 rpms
Old Apr 1, 2017 | 7:59 AM
the fuel system may be leaking down...losing it prime. prime the fuel rail before starting; cycle the key to run for 2 seconds and repeat 3x before turning the key to start.
If it starts normally after priming, the fuel system is leaking down; either back to the tank or from the injectors into the cylinders. a pressure test with a fuel gauge can confirm this.
Old Apr 1, 2017 | 6:26 PM
what part would be causing it to leak down
if it was doing that
