2500HD with 4l80e dropping out of gear
Old Jul 18, 2018 | 9:47 AM
The dude's Avatar
Default 2500HD with 4l80e dropping out of gear
I have a 2001 Silverado 2500HD with a 4l80E transmission. Recently I have been having an issue with the transmission dropping out of gear when engine braking or just coasting. The RPMS will drop and I hear a fast clicking sound. If I rev the engine up a bit it goes back into gear. I have had this happen in 2nd-4th gear. Otherwise I have had no issues with the transmission.
Any ideas what might be causing this? Could it be the torque converter?
Any thoughts on this would be greatly appreciated.
Thanks!
Old Apr 7, 2019 | 4:37 PM
nonosrcng's Avatar
So I joined the forum because I am having the same problem. Have you had any luck, did you get it fixed? If so what was your issue?
