4wd Issues
Old Nov 12, 2019 | 5:17 PM
Dillbart's Avatar
Default 4wd Issues
Hey! i have a 2005 chevy silverado 4.8 with autotrax and we had issues switching into 4wd found that changing the transfer case motor had resolved the problem, but now the truck will not switch again. Tried a new t case motor and dash lights just blinked indicating it was trying to change but didnt even hear any noises from the tcase motor. i tested the switch with a mulitimeter it worked fine. i removed the front axle actuator and manually set it to activate the front axle to be powered and had attempted to just be rid of the t case motor and manually switch the tcase into 4wd. but at every setting i try i cannot get the front wheels to spin. i had got the truck into 4lo but still no spin from the front tires. thanks much!
Old Nov 12, 2019 | 7:25 PM
oilcanhenry's Avatar
Probably your transfer case control module.TCCM is gone, They run around $130-140 USD. Probably less if its a reman unit..
Perkins315
Nov 20, 2018 5:55 AM
GrizzzlyBear_406
Mar 7, 2018 4:17 AM
rob1020
2007 - 2013 (GMT900)
Jan 26, 2017 1:21 PM
04silveraydo
Dec 31, 2014 11:08 AM
Maddog53
Sep 13, 2009 9:00 PM
