AC clutch stuck on
Old Jun 23, 2023 | 8:48 AM
  #11
chem_man's Avatar
15 Year Member
Originally Posted by Obxer@2360
AC button stays lit but clutch goes off.If I push ac button off in other modes light goes off clutch stays on
Obxer@2360,
Are you sure this is accurate? If so, then things are working in reverse of what they should be. It should be light ON Clutch ON. Light OFF Clutch OFF.
Old Jun 23, 2023 | 1:00 PM
  #12
Obxer@2360's Avatar
Originally Posted by chem_man
Obxer@2360,
When ac light is on clutch is on until you put selector in floor mode clutch goes off.when ac button is turned off in all modes clutch continues to run never shuts ac off
Old Jun 25, 2023 | 9:03 AM
  #13
chem_man's Avatar
15 Year Member
It sounds like something is shorted such that the clutch remains engaged at virtually all times. Have you checked the AC relay?
If the AC relay is OK, then perhaps the HVAC controller is bad.
Good Luck!
Old Jun 25, 2023 | 10:03 AM
  #14
Obxer@2360's Avatar
Good Luck!
I will check them thanks
tone4life2006
Mar 15, 2022 5:13 PM
radar1234
Jun 26, 2018 1:55 AM
klemeeri
Jan 11, 2012 5:37 PM
skinautique
Apr 21, 2011 6:43 PM
will_09
Nov 21, 2006 1:59 AM
