AC clutch stuck on
Old Jun 20, 2023 | 1:15 PM
Obxer@2360's Avatar
Default AC clutch stuck on
AC clutch turns off when put in floor mode will not shut off when ac is switched off constantly runs.High and low gauges are perfect ac is 40 degrees.Has anyone else had this issue?
2000 silverado
Old Jun 21, 2023 | 3:10 AM
oilcanhenry's Avatar
No, but I don't use floor mode on my A/C unit when it's hot outside. 40 degrees F is a great reading and so I don't think it's the A/C compressor since it's running nice and cold. Likely some kind of electrical issue of some kind on your Chevy. Perhaps it's the temperature control unit on the dash causing this issue. Does the A/C work when on the dash/floor setting on the control panel or simply just the floor setting? Are you using the recirculate mode?
Old Jun 21, 2023 | 7:12 AM
Obxer@2360's Avatar
Yes I am using recirculating mode cold air comes out of all modes except floor mode when in floor mode clutch shuts off and floor air is not cold
Old Jun 21, 2023 | 2:16 PM
chem_man's Avatar
15 Year Member
Wat happens if you push the AC button when you select the floor air outlets? Also, does the AC light on the AC button illuminate when in floor mode?
Old Jun 21, 2023 | 2:47 PM
Obxer@2360's Avatar
AC button stays lit but clutch goes off.If I push ac button off in other modes light goes off clutch stays on
Old Jun 21, 2023 | 8:55 PM
chem_man's Avatar
15 Year Member
Does your HVAC system have a manual or automatic system. Manual is where you set a temperature and the system continuously blows air at a given temperature, Automatic is where the system blows air that can get colder or warmer as needed to maintain the temperature you set it to?
Old Jun 22, 2023 | 7:47 AM
Obxer@2360's Avatar
I am not sure my control are the type that **** ranges from cold to hot as you turn the **** the other **** sets air to blow from vents to floor to defroster etc
Old Jun 22, 2023 | 12:16 PM
Both my 1998 K-1500 and 2015 Malibu can be set to floor/dash air outlets, as well as recirc. Yours cannot?
Old Jun 22, 2023 | 1:12 PM
Obxer@2360's Avatar
Yes one **** controls fan speed one to five next controls vents face floor and face floor only then defroster next **** is temperature control
Old Jun 23, 2023 | 8:18 AM
chem_man's Avatar
15 Year Member
You likely have a manual control HVAC system based on your answer.
