Brake lights go on when ignition turned on
Old Apr 6, 2024 | 2:05 PM
Renegademechanic's Avatar
Default Brake lights go on when ignition turned on
I have a 2000 C1500 that has me baffled. I just put in a new steering column as the wires from the old one were burnt out. I plugged everything in, and when I turn on the ignition, the brake lights go on. The 3rd brake light doesn't light up though. Signals work, but can't figure out the brake light system. Anyone else have a similar problem? I read somewhere that a bad ground can do this. There's only about 100 of them to check. Any help would be very much appreciated. Thanks!
Old Apr 6, 2024 | 2:45 PM
Welcome from Florida. Check your wiring harness that plugs into the steering column. There may be some damaged wires in there.
PatrykKoul
Apr 26, 2023 9:14 AM
kellyjames
1988 - 1998 (GMT400)
Apr 18, 2021 4:25 PM
jtinker101
Mar 31, 2020 2:56 AM
Codexfab
Jul 11, 2011 11:44 AM
tylerowen
Sep 13, 2009 10:20 PM
