A/C cycles through all modes then sticks on defrost.
Old Aug 26, 2023 | 3:50 PM
wferd's Avatar
Default 04 Silverado A/C cycles through all modes then sticks on defrost.
2004 Silverado 1500 2wd.
I just got my transmission rebuilt and replaced the battery but when I start the truck, the AC blows out of the floor vents for about 5 seconds, then the front vents for 5 seconds and then it comes out of the defrost vents but it stays there. I’ve replaced the mode door actuator and even tried the AC control module but it’s still having the same issue. Any ideas what could be causing it?
Old Aug 26, 2023 | 4:45 PM
Defrost is the default setting when there's insufficient vacuum.
So you could could have a cracked/leaky hose or vacuum tank, checkvalve that has gone bad, etc.
You should probably post what you're driving.
Old Aug 26, 2023 | 5:10 PM
wferd's Avatar
Should should probably post what you're driving.
Its a 2004 Silverado 1500 . This is the first time I’ve used this so it’s all new to me
Stormyj
2014 - 2018 (GMT-K2)
18
Jun 13, 2024 6:07 PM
Daniel Mogan
1988 - 1998 (GMT400)
Nov 5, 2022 12:54 PM
Efrain Alvarez
Nov 30, 2021 3:26 PM
garrettathomas7
Aug 10, 2021 7:38 AM
sleeper bird
Nov 11, 2012 6:39 PM
