Can't explain, engine ran high at low speed
So it seems like every week something is happening weird with my baby. 2004 v6 silverado 1500 base model.
I replaced dash light, plugs and wires, main ignition coil, harmonic balancer, water pump, alternator, battery and a few smaller things within the past year. Now since im working from home I basically drive it once a day. This week it froze so didn't drive it for 3 days straight.
I went out and it was driving perfectly fine and then I felt something weird while I was slowing down at a light my truck wanted to keep going. Its almost like the pedal was stuck as if I floored the engine but my foot was off the gas pedal.
Luckily I was turning into a store parking space so I put it in park and I could hear my engine going full ham. I quickly turned off my truck. Unsure what to do i went inside the store for about 3-5 minutes came back out and turned on my truck. Opened the hood and it was running fine again, didn't happen the rest of the day and I've never had that happen EVER! No warning lights nothing.
I went and dumped a can of Lucas in the gas tank. Could it be that maybe something stuck cause of the cold weather or? My truck sits outside and it did freeze for 2 days. It was a very weird experience for me and Im super worried. Couldve caused an accident if my foot wasnt on the brake or blew my engine.
It was like my truck was wanting to go when idle and I mean at a high level like at 20 mph my engine was running if i was going 90 mphr.
Remember to shut the ignition off or put it in neutral, but I wouldn't take a chance driving it at all until its repaired. .
One, the bulb for the CEL could have burned out.
Two, there are codes called Pending Codes which have not yet appeared enough for the PCM to store a "regular" code and illuminate the CEL.
Three, there are also codes known as Historical Codes that might be able to provide insight into what is going on.
Remember, it takes a certain number of "cycles" or times something happens before the PCM has the CEL illuminate.
CEL LIGHTS are not burned out or off. That is a fact I know. There are not historical codes only other ones I checked which cause me to replace wires, plus and ignition coil and since my truck has been running smooth other than this weird incident. That will not solve my dilemma
1995suburb
Oct 1, 2024 5:21 AM
blackbok
Jul 19, 2013 9:49 AM
sniper7
Mar 3, 2012 10:36 AM
