chugs loses power falls on its face sometimes back fires
Old Jun 22, 2024 | 12:19 PM
Maschke82's Avatar
Default chugs loses power falls on its face sometimes back fires
1999 Silverado 1500 5.3
Ok guys if I start my truck and go it chugs loses power falls on its face sometimes back fires, but eventually comes out of it. If I start the truck let it run for a bit then drive it works as it should. This happens every time I start the truck don’t matter if I’m in the gas station for a few minutes it acts up. I noticed long periods of sitting like after work Or over night it’s worse. What do u think the problem is? Air filter clean plugs new not long ago, flue pressure problem? Sensor?
Old Jun 22, 2024 | 12:30 PM
ChevymyBeast's Avatar
Potentially the injectors are clogged or maybe a bads connection.
Old Jun 22, 2024 | 8:38 PM
backfiring: https://www.carrchevrolet.com/servic...e-backfire.htm
Old Jun 23, 2024 | 10:01 AM
chem_man's Avatar
15 Year Member
First, get a fuel injection system pressure gauge (you can "rent" them from AutoZone, Advance, Carquest, O'Reilly) and see what your fuel pressure is and test the fuel pressure regulator while you have the pressure gauge.
You can find the specifications here - https://charm.li/
If the fuel pressure is in spec, the fuel pressure regulator is working properly, I would add a 20 ounce bottle of Techron Complete to the gas tank immediately before your next fuel fill-up.
Good Luck!
Old Jul 4, 2024 | 1:24 AM
Just Tim's Avatar
Another thought is if you still have catalytic they could be failing ... there is a product called cataclean specific for cleaning them out a little on the spendy side but in my opinion I install this in a lot of customers cars to buy them time to replace .... it doesn't "fix" it just cleans out the exhaust
Old Jul 4, 2024 | 12:38 PM
I have strong doubts about the so called catalytic "cleaners"
bitshift
Jul 31, 2024 9:07 AM
bmusic621
10
Jan 5, 2023 5:17 AM
nisaac24
Feb 24, 2011 10:28 AM
jay3250
Oct 3, 2007 12:48 PM
PARKER115
Nov 30, 2006 12:26 AM
