Coolant Frustration - 1999 Chevy Silverado
Old Jul 1, 2021 | 6:52 AM
kwhitehurst346's Avatar
Default Coolant Frustration - 1999 Chevy Silverado
Although I do not see any signs of overheating and the thermostat gauge looks good, I have had the Low Coolant light come up 2 times in 3 days. After I shut off the engine and when I go to check it, it is really low in the reservoir. As the engine starts to cool, the reservoir starts to fill up. It fills up faster if I slowly open the cap to let a little air in. It's as if, the vacuum is pulling it all in. It will fill back up almost to the full line in the reservoir tank. A little history, I have recently replaced the thermostat and most recently replaced the water pump (approx a month ago). There are no signs of leaking of coolant that I can see but I do smell it coming from the engine compartment when I get out of the truck. If there is a small leak, it must be occurring while driving. Any thoughts or suggestions, would greatly appreciate it.
Old Jul 1, 2021 | 10:16 AM
does the vehicle use a surge tank ...ie surge tank is pressurized...coolant reservoir is not pressurized.
Old Jul 1, 2021 | 1:05 PM
Yes, it has a reservoir. Every time I take off the cap, it acts pressurized. When I take off the cap, the tank starts to fill back up.
Old Jul 1, 2021 | 2:27 PM
I need to know what type of system it uses?? post a pic of the surge tank/reservoir. Include engine size
99 old body style uses a different design than a 99 new body style.
Old Jul 22, 2021 | 4:52 PM
2001 chevy silverado's Avatar
search past threads in this forum: i'm unsure if this applies to 1999 or just 2001
YOU MIGHT HAVE THE FAMOUS PLASTIC HEAD GASKET PROBLEM
mexico put in plastic head gaskets (abhorible!) , then GM used used canadian recycled fluid which ate plastic (also a seedy practice). the result is: holes in plastic allow coolant to be eaten in the combustion chamber by leaking through holes in plastic - and you think your coolant keeps "going low"
the answer is: GM has replacment aluminum/plastic gaskets and says not to used the ?DEK coolant (use only non-recycled Prestone made in usa fluid with the new head gasket !)
note: i assume it's going very low (under minimum ilne) not just "being lost after topping off". if you fill to top cold, and drive until hot: then it's supposed to spill out until slightly lower than "full hot" that's it's design
Old Jul 23, 2021 | 1:18 PM
Canadian recycled fluid...new to me.lol Where did you get that?
Giovanni Ruiz
Jun 13, 2018 8:09 AM
otto11
Dec 28, 2013 11:53 AM
otto11
Jul 10, 2013 2:37 PM
Bbell
Feb 5, 2013 8:28 PM
Colt Hero
Oct 8, 2008 12:46 PM
