Coolant leak
Old Aug 26, 2020 | 10:46 PM
Brandon Belcher's Avatar
Default Coolant leak
Hi i have a 2002 chevy 2500hd 4x4. I keep having a problem with my coolant leaking out but i cannot figure out where its coming from. I pressure tested it and didnt lose any pressure so i left it on over night in the shop and came back in the morning and still holding strong and no water under truck. I changed the cap and when i start the truck i noticed coolant comes out of the overflow tube at a slow drip sometimes bit i wouldnt think thats enough to drain my coolant out. Any ideas.
thanks
Old Aug 26, 2020 | 11:36 PM
are you overfilling the reservoir?
Old Aug 27, 2020 | 9:02 PM
No and today i drove to work abd 4 hrs later i went to check the water and the reservoir had so much pressure the cap blew off when i unscrewed it. I was thinking the radiator is clogged. What do you think.
Old Aug 28, 2020 | 7:42 AM
Is it overheating?
Old Aug 28, 2020 | 8:41 PM
No its not over heating but after i drive for a few min the thermostat starts jumping from 205 down to 160 and right back up but doesnt go over 210 and today i drained all the coolant out and put flush in it to see if maybe the radiator is clogged and i also noticed that i have water coming out if my exhaust but i have no water in the oil it looks good.
Old Aug 29, 2020 | 3:41 PM
chem_man's Avatar
15 Year Member
Some water coming out of the exhaust is normal - it's condensation of the water formed from the process of combustion. You might want to check the compression of the cylinders to see if you have a bad head gasket. Identical readings in adjacent cylinders (like 1 & 3, 2 & 4, 5 & 7) can indicate a bad head gasket. Also, your posting about there being so much pressure in the expansion tank that it blew off the cap when you started unscrewing it is also a clue for a bad head gasket.
Good Luck!
Machine213
Sep 19, 2017 12:03 AM
gixxerscott
Jan 27, 2017 12:56 AM
Jacob Orrico
1988 - 1998 (GMT400)
Apr 25, 2016 2:05 PM
mygreenihc
Aug 5, 2015 11:09 PM
ffdaryl
Mar 1, 2007 2:52 AM
