Dash brake light on
Old May 30, 2023 | 4:50 PM
abunai23500's Avatar
Default Dash brake light on
2000 K3500 LS
The dash brake light came on.
Brakes work fine.
Disconnected the parking brake switch, but the light is still on.
ABS light NOT on.
Anyone have a diagram for this????
Old Jun 19, 2023 | 7:25 AM
Reubone's Avatar
Brake Fluid level maybe?
Old Jun 19, 2023 | 12:03 PM
Fluid is fine, but I'll check the sensor.
I think it might be the proportional valve.
Don't see any leaks.
I'll try and reset it, bleed it, and see if it goes out.
Old Jun 22, 2023 | 12:26 PM
Gumby22's Avatar
Originally Posted by abunai23500
2000 K3500 LS
Brakes work fine.
ABS light NOT on.
The ABS module can also turn on the red brake light. It’s on a separate control circuit so it’s possible for the module to turn on the red light and not the yellow ABS light.
A quick test is to unplug the module and turn the key on - if the light is out after a few seconds, the module is malfunctioning.
The same can be done for the pressure differential switch - no bleeding necessary.
Old Jun 22, 2023 | 1:05 PM
I'll give it a try.
Thank you
abunai23500
May 19, 2022 3:41 PM
Stacey Conley
Jan 25, 2022 4:37 PM
Lil Rome
Oct 11, 2017 4:42 AM
bkordrs
May 15, 2011 11:05 AM
hatch92
Jul 3, 2006 10:45 PM
