Digital Automatic Climate Controller Not Changing Temp
Old Nov 1, 2024 | 6:19 PM
Mikmac75's Avatar
Default Digital Automatic Climate Controller Not Changing Temp
Please Help!
I have a 2004 GMC Sierra 2500HD Duramax, when I try to change the cabin temperature the temperature usually goes in the opposite way, or jumps around, worst is trying to turn the temperature warmer, if I’m at 69 and try to turn it up it’ll drop down to 63 and just bounce around in a low set of temperatures. I’ve been told it could be a faulty BCM or Actuator motors. When I do finally get it to the temperature I want everything works properly, everything blows through the vents I select and the temperature I select. Just need a heap of patience getting to the temp I want and I don’t have a lot of patience.
biglg
May 21, 2021 10:08 PM
Frank3
Jan 9, 2018 9:37 PM
Punit Yatnal
Apr 5, 2016 1:23 AM
66Stepside
Sep 10, 2014 12:59 PM
cs3030
Aug 20, 2014 6:46 AM
