Drove fine for 3 miles, Died at stop sign and restarted then ran horribly
Old Jan 21, 2025 | 10:41 PM
Bannerlund24's Avatar
Default Drove fine for 3 miles, Died at stop sign and restarted then ran horribly
Hey, so I have a 2004 4.8 L silverado. I live in North Dakota and its the middle of winter here, The other day it was negative 27 outside and I went to start my truck, It cranked but no start. So I then plug it in for two hours then try to start again, battery is dead. It is then put in heated shop because the hood latch was frozen and I couldnt get to the battery. Flash forward to today, I take it out of the shop to run to get fuel and everything seemed great, battery had been tested and showed that it was fine. It made it 3 miles then I hit the brakes to stop at the stop sign and it dies. I restart and it ran like crap then died. My father drove it home but had to keep it revved up or else it would die, idled horribly and really low, Its my daily so any help would be appreciated. My first chevy so I have no clue whats going on.
Old Jan 22, 2025 | 8:05 AM
Welcome from Florida. Is the check engine light on? If so, what is the code?
Old Jan 22, 2025 | 11:52 AM
chem_man's Avatar
15 Year Member
Evenif the check engine light is not on, you need to retrieve the Diagnostic Trouble Codes (DTCs) from the OBDII system. You also should check to see what the fuel pump pressure is using a fuel injection system pressure test gauge.
Here is a link to a professional level Service Manual:
https://charm.li/
Good Luck!
Old Jan 22, 2025 | 12:16 PM
No check engine light, Im planning to check the codes after work tonight, ill let you know when I find out what they are.
Old Jan 22, 2025 | 12:18 PM
https://charm.li/
Good Luck!
Ill run the codes tonight, and see if I have a tester, then ill let you know.
Olschool0097
Traverse
Feb 12, 2023 2:58 PM
300k+vortec
Jun 1, 2022 5:39 PM
jasonh2244
May 9, 2020 11:02 AM
Tony_B.
Aug 27, 2012 1:40 AM
neto1978
Mar 15, 2008 3:21 PM
