ECM diagram
Old Jun 25, 2023 | 4:08 AM
Slytlyused's Avatar
Default ECM diagram
2001 silverado 2500hd LT 6.0 L v8 gas does anyone have the ECM pin out diagram.also I have read there is a fuel module or some kind of module above spare tire I've looked and don't have one .is there a reason why
thank you
Old Jun 25, 2023 | 4:40 PM
2001 is to old for a fuel pump control module....you will have a fuse and relay in the ubec to power the fuel pump.
post the specific circuits that you need for a pinout.
Old Jun 25, 2023 | 11:42 PM
Slytlyused's Avatar
I have crank no start issue I think it might be anti theft/passlock but I'm getting pulse at injectors(noid light test .and injectors 013 ohms .been three months no ride at a point dont know what to do. but pin out on anti theft /passlock and injectors gotta find problem
Old Jun 26, 2023 | 12:26 AM
if you had anti-theft failure, there would be a warning light in the cluster, and no injector pulses.
have you tried using starting fluid to start it?
Old Jun 26, 2023 | 3:19 AM
Slytlyused's Avatar
yes and it starts then
Old Jun 26, 2023 | 3:27 AM
try measuring the fuel pressure
Old Jun 26, 2023 | 3:35 AM
Slytlyused's Avatar
ok I will check it this morning
Thank you so much for your help I'm at my wits end .I truly appreciate it
rnorman4
Sep 10, 2022 9:31 AM
not2bad
Mar 6, 2020 8:09 PM
Domino101
Oct 14, 2014 6:35 PM
alxsml
Apr 9, 2013 11:21 AM
Knightwatchman
Camaro
Apr 14, 2010 7:49 PM
