Engine died while driving...
Old Jun 19, 2018 | 1:08 PM
NeilS's Avatar
Question Engine died while driving...
Thanks, in advance, for any help or ideas on this. Can't afford to take it to a shop right now.
Coming home from work and the engine suddenly died. No check engine light. No catastrophic noises or anything like that. The engine turns over but will not start. Towed home and put a code reader on it but it did not show anything. Replaced the crank shaft position sensor and a fuel pressure check. Fuel pressure up to 50 but bled down to 30 within a minute or so of being shut off. Still will not start. Haven't put starting fluid down the manifold, but I guess that the next step. Any ideas of where to go from here? I have a tendency to start replacing parts, ***** nilly, and can't afford to do that. I have a Haynes manual and am pretty mechanical. Thanks again for any advice.
Old Jun 19, 2018 | 4:26 PM
Rednucleus's Avatar
Welcome! Please post make/model/motor/mileage etc
Old Jun 19, 2018 | 8:57 PM
no way fuel should bleed of that fast. if you have a fpr...check to see if fuel is in the vacuum line.
Old Jun 20, 2018 | 10:03 AM
NeilS's Avatar
Doh! Rednucleus, that would be helpful, now wouldn't it. 2005 Chevrolet Truck Silverado 1500 2WD 4.3L FI OHV 6cyl . Mileage: 182211 Thanks for the welcome!
Kind Regards,
NeilS
Old Jun 20, 2018 | 10:39 AM
NeilS's Avatar
Thanks, tech2, I will check that. Appreciate your help.
Kindly,
NeilS
Old Jul 3, 2018 | 5:22 PM
NeilS's Avatar
Wanted to update this thread. After a ton of head scratching, I decided to take it in to my mechanic. Turns out the electronic ignition control module was bad. Replaced and truck now runs great.
Kind regards,
Neil
Old Jul 3, 2018 | 11:32 PM
thanks for the fix
in the future...to diagnose a crank, no start...you need these 3 things
-check spark
-check fuel pressure
-check compression
