engine dies soon after starting
Old May 7, 2024 | 11:43 AM
dhk's Avatar
dhk
Default engine dies soon after starting
I’m having trouble and need help! My 02 Silverado was broken into and they destroyed the key switch cylinder and the security wires. I replaced the cylinder and the ignition switch electrical harness. It will start but instantly shuts off. I think it’s a security issue but having no luck figuring it out.
Any help is much appreciated!
Old May 7, 2024 | 7:34 PM
The antitheft system is not disarming. I'm guessing you didn't replace with matching coded lock+key set, which means the system has to be reprogrammed by a dealer/locksmith.
Search the forum how to do a passlock reset and hope for the best.
Old May 7, 2024 | 8:57 PM
frank1's Avatar
I replaced the ignition wiring harness, under my steering column, with a used waring harness from a parts truck. I removed the ignition switch and replaced it during the parts replacement. The truck didn't need to be reprogramed or any thing like that buy there's a little push button switch just above the switch that caused a no start because it wasn't sitting correctly.
https://www.rockauto.com/info/903/1S5974_10.jpg
Old May 8, 2024 | 8:06 AM
dhk's Avatar
dhk
Hey frank, can you send me a picture where that is? Thanks!
Old May 8, 2024 | 9:10 AM
frank1's Avatar
Click on the rock auto link
Old May 8, 2024 | 9:14 AM
dhk's Avatar
dhk
Didn’t get a link
Old May 8, 2024 | 9:40 AM
dhk's Avatar
dhk
Ok I gotcha! Didn’t see that, thanks!
Drivingmad44
Feb 2, 2023 4:42 PM
Jerj
2007 - 2013 (GMT900)
Nov 16, 2021 12:31 PM
StevenJudy
Feb 10, 2020 9:00 PM
eberkatie
Apr 12, 2012 7:38 AM
r970
Jun 3, 2007 8:16 AM
