Evap problems on 99 silverado.
Old Jan 29, 2021 | 8:09 PM
Ricky Mccurry's Avatar
Default Evap problems on 99 silverado.
Recently my 5.3 vortec has been giving me trouble starting after the engine is warm. Starts great first thing in the morning,but after driving for awhile. It starts having issues starting. I'm getting code po446 evap emissions system vent control circuit and po420 catalyst system low efficiency bank one. Was getting po102 mass air flow circuit low input. Replaced mass air flow sensor and that code went away. Have replaced purge valve, crankshaft position sensor,and fuel filter. Still having issues starting when warmed up and has rough idle when it does start( just till I put it in gear). Any help would be appreciated.
Old Jan 29, 2021 | 8:36 PM
kevinkpk's Avatar
Can't believe emission issue would cause this other than a plugged cat. With that I'd suspect a misfire code, you might look into the cat.
Old Jan 29, 2021 | 10:59 PM
chem_man's Avatar
15 Year Member
Ricky, did you replace the EVAP purge valve that is behind the throttle body, or the EVAP vent valve which is located up and behind the driver's side rear tire? I ask because you said you got a P0446 code (which is for the VENT valve) and you replaced the Purge valve.
Old Jan 30, 2021 | 4:39 AM
I replaced the one behind the throttle body
Old Jan 30, 2021 | 7:26 PM
chem_man's Avatar
15 Year Member
Well, the EVAP purge valve solenoid normally throws a P0443, P0444.or a P0445 code. Since you have a P0446 code, that is for the EVAP vent valve which is located back by the driver's side rear tire. There is a filter inside of the EVAP vent valve that gets full of dirt and then sets the P0446 as a result. The solution is to install the revised EVAP vent valve with a remote filter. The filter is placed up by the top of the transmission and is connected using a length of heater hose. I'm attaching a copy of the TSB from GM.
Not sure if this will remedy the P0420. How are your Oxygen sensors?
Old Jan 31, 2021 | 8:37 AM
Old. I have news ones to be installed,just haven't gotten to it yet.
Old Jan 31, 2021 | 8:59 PM
most hard starts after a hot soak are related to fuel pressure leakdown into the manifold from the fpr or injectors into the cylinders. it creates a flood like conditions.
Old Jan 31, 2021 | 9:40 PM
What is fpr? Fuel pressure regulator?
Old Jan 31, 2021 | 11:03 PM
yes...if the fpr has a vacuum line to the intake manifold...check the line for the presence of fuel. if yes replace fpr.
Old Jan 31, 2021 | 11:14 PM
Thanks,I'll check that tomorrow
