Fan/Clutch Assembly
Old Jun 3, 2016 | 1:40 PM
Larrycarol's Avatar
Default Fan/Clutch Assembly
How do I remove the fan/clutch assembly from the water pump? It is screwed onto the shaft of the water pump. How do I keep the shaft from turning while trying to unscrew it? This is on a 2003 Silverado 1500 with the 5.3L engine.
Old Jun 3, 2016 | 11:27 PM
Jacksonojsparrow's Avatar
Default Got to get tool kit
Harbor Freight carries a kit for it. I always jammed it so it can't spin. Pain in the a** Lord knows
Old Jun 3, 2016 | 11:29 PM
hicksvilleshick's Avatar
Typically use a specialty tool you can rent from parts stores.
Old Jun 4, 2016 | 8:50 AM
fan clutch wrench and a hammer works.
I use an air hammer with a long chisel bit. a couple hits straight down to create a notch and them a angle hit into the notch to spin the fan off....off in seconds.
Old Jun 4, 2016 | 9:10 AM
This works well too. lol
Old Jun 4, 2016 | 11:16 AM
My new favorite way!
Old Jun 4, 2016 | 12:24 PM
cleveland63b's Avatar
you can get wrench sets, the one I have has an adapter for use with an air hammer and I just leave the belt on until its loose
Old Jun 5, 2016 | 3:23 PM
Larrycarol's Avatar
Problem solved. I saw different special tools online and just made one up
