Front and rear differential swap
Old Aug 22, 2020 | 4:59 PM
Rjcapt's Avatar
Default Front and rear differential swap
Quick question here.
i just replaced the front differential and rear axle in my 2001 Silverado. They were used and supposedly a matched set.
I have all four wheels (tires and wheels removed) off the ground, and when the truck is in 4wd and in drive, the front wheels turn almost twice as fast as the rears.
I don’t think this is right and I don’t want to damage anything by driving it like this.
Other than having mismatched gears, any thoughts?
thanks
pete
Old Aug 22, 2020 | 6:33 PM
try applying some brake pressure while you do it.
Old Aug 22, 2020 | 6:58 PM
Rjcapt's Avatar
i did that, and they both (front and rear) slow down and stop. I’m just wondering if the front having less “free wheel” drag on it, runs faster, but with an even load won’t.
Im not sure, I’ll put the wheels back on and try it on the ground (cautiously). I’m just used to solid axles and geared transfer cases where the two are mechanically tied.
Thanks for the input.
Pete
Old Aug 22, 2020 | 7:14 PM
could be the diff walking...count the driveshaft revolutions
RPetty_43
Astro
May 17, 2018 8:10 AM
Georooney
20
Jan 11, 2011 1:05 PM
lknox21
Sep 5, 2009 7:29 AM
2001_z06
Corvette
Oct 29, 2007 10:19 AM
Tommygunz
Nov 28, 2006 3:52 PM
