Front of rear Leaf spring mount
Old Jun 21, 2020 | 8:54 PM
NickFarris123's Avatar
Default Front of rear Leaf spring mount
So I have a 2004 Chevy Silverado z71 crew cab. Truck is in wonderful shape other than those leaf spring mounts. I never thought to check those when I bought it but as I’ve done research they are part of the frame. I was wondering if anyone else has encountered this issue
Old Jun 22, 2020 | 3:14 PM
as long as the frame rail is ok...have a bodyshop weld in a new bracket.
Old Jun 22, 2020 | 9:33 PM
Frame rail is fine, issue is they don’t make that bracket so I have to find someone to either make one or go to a junk yard and start hacking away to get one.
Old Jun 23, 2020 | 3:27 AM
Gumby22's Avatar
This is an easy fix but it does require some skill with a welder. If you’re not comfortable welding, I recommend going to a shop or getting a friend/relative that can help you.
Support the frame rail and remove the bolt from the leaf spring.
Use vice grips to pull the bracket back flush. Drill an 1/8” hole at the end of the crack to keep it from spreading further, then prep and weld the crack. Grind it flat, then weld a flat washer to the mount. Either a 1/2 or 9/16 washer should fit over the bolt for the leaf spring. Once the welds have cooled, spray paint to protect them.
It’s good practice to disconnect the battery when welding on a vehicle.
Old Oct 16, 2022 | 11:03 PM
RaJenHell's Avatar
Did you ever get this fixed? I'm currently experiencing the same thing on my 2014 except mine is rotted off and only thing supporting it is the bolt. Stupid the backs are replaceable and the front isn't. Dealership told me to look online cause they don't know what I can do.
Merica
May 27, 2018 3:37 AM
SPCHEVY1
Jul 31, 2015 2:12 PM
pickawaykid
Jun 7, 2012 6:16 PM
GM Fixer
Aug 2, 2011 5:59 PM
s34n
Jul 16, 2010 10:40 PM
