Funky shaped tiny pin thing
Old Nov 4, 2023 | 12:47 PM
Twistymcfly1's Avatar
Default Funky shaped tiny pin thing
Hi everyone. Can someone tell me what this is? I pulled the pump out of my 4L60E and there was a teeny tiny funky mushroom shaped metal pin thing just chilling there on the ledge where the pump sits. I had the transmission laying on its side so it could have fallen out from anywhere and maybe scooted down when the pump came out.
Old Nov 4, 2023 | 3:33 PM
it looks like a sheared off rivet
Old Nov 4, 2023 | 3:46 PM
Not sure if this helps...it was sitting right on the lip of the pump housing when I pulled the pump out (tranny laying on it's side) The only thing I can think of is I forgot to unplug the pump filter sensor that goes in from the wire harness into the side of the pump and it brok in half, with half of it still in the pump. Which is no problem I have an extra harness. Anyway, I don't think it would have fallen out of the filter though. I could be wrong. I actually already rebuilt this transmission and put it back together. The only reason I took it back apart is I heard a check ball rolling around in the pan. I was really irritated so I kind of just hurried up and pulled the pump out without taking out that one sensor for the wire harness.
Old Dec 14, 2023 | 11:09 PM
jonathanerodman32@gmail.com's Avatar
same thing in my 2007 suburban. You find out what it is??
Old Dec 19, 2023 | 10:17 PM
No not really. I had this same little pin fall out of another transmission that I was taking apart too. On both of those trannies I got in a hurry and forgot to pull out that filter/sensor that goes from the solenoid harness into the side of the pump before removing the pump. I ended up braking off that filter piece on both of them. It might have something to do with that but not really sure.
Old Mar 14, 2024 | 8:57 PM
​​​​I did the same thing! Broke that piece.
Joe_The_Guy
Oct 29, 2021 9:50 PM
gsayers66
Feb 27, 2017 10:06 AM
gsayers66
Feb 3, 2017 11:07 AM
97Chev1500
Sep 21, 2010 12:56 AM
sirsedrith
Nov 4, 2009 10:41 AM
