Fuse block issues
Old Dec 25, 2020 | 12:43 PM
Kendall Collins's Avatar
Default Fuse block issues
03 1500 Z71 5.3, under the hood fuse panel only showing about 1/4 of the fuses have current? Truck runs and drives, most of the time like crap but I was trying to install an aftermarket radio and was having trouble locating power Wich led me here. Thanks in advance
Old Dec 25, 2020 | 1:00 PM
kevinkpk's Avatar
Not all electrical items are used. You may have a fuse in place, but the vehicle doesn't have that option. Example, you may have a spot with fuse for electric seats, but your vehicle doesn't have that option.
Old Dec 26, 2020 | 7:00 AM
Does the pigtail for the old radio have power ? The yellow wire should have power all the time and the red wire should have power with the key on. If not check for a blown fuse or broken wire.
Old Dec 26, 2020 | 10:46 AM
therewolf's Avatar
Hey Kendall Collins, Welcome to the Chevrolet Forum.
There may or may not be a radio port, on the ignition switch, for an 03. (sorry)
I ran into the same issue with my 04; what you need is to research the dataport adapter, (it also works the seat-belt chime)
This is where you will need to make your radio hookup.
A new dataport adapter for your new radio, may be in order.
Brent Vette
Aug 31, 2019 7:33 PM
Markie-moo
2007 - 2013 (GMT900)
Mar 10, 2019 1:16 PM
Kim Hodge
Aug 11, 2017 8:18 PM
flrtrader
Nov 18, 2011 5:28 PM
punkieys17
Dec 26, 2007 5:24 PM
