Galley
Old Sep 12, 2024 | 2:25 PM
galley's Avatar
Exclamation Galley
I have a 2001 Silverado 2500 HD, I cannot get there 4x4 to work. No lights on the selectors switch, 4WD Needs Service is lite on dash and nothing happens when selector switch is used. I have checked all fuses, cleaned ground contact on frame under driver's side replaced selector switch and took a wild guess and replaced TCCM. Nothing so far has made any difference. I don't want to make any more wild guesses, any help will would be appreciated. Thanks Galley
Old Sep 12, 2024 | 4:08 PM
JBAR68's Avatar
You have a shift between the gearshift lever and the selector. Put yourself in P, and move the lever until it lights up.
Old Sep 14, 2024 | 12:14 PM
galley's Avatar
Post
I have electronic 4 WD and see no level that you mention. I have 4WD selector buttons on the left side of my dash, and the lights on that cluster are not on to indicate what I am in, 2 HI, 4 Hi, etc.
Old Sep 15, 2024 | 8:48 AM
frank1's Avatar
Most of the time its the encoder motor on the TC.The last time this happened to me I got a ued one from the wrecker. I had a 2001 yukon 2500 slt at the time.
Old Sep 15, 2024 | 9:07 AM
Gumby22's Avatar
Have you checked all the fuses for the 4WD? There’s more than 1 fuse block - refer to the fuses section in your owners manual.
Don’t just look at them - use a test light or meter at the test points on the fuse with the key on to verify they’re good.
johnye75
2007 - 2013 (GMT900)
Dec 17, 2024 1:50 PM
J.Chesnut
Oct 14, 2023 2:15 PM
Mr.Magoo
Oct 4, 2021 9:37 AM
Jacob_CM
Jan 29, 2014 11:45 PM
MEH
Jan 11, 2013 2:48 PM
