Ground for instrument panel
Old Aug 26, 2017 | 5:05 PM
kenatofc's Avatar
Default Ground for instrument panel
My 03 Silverado 1500 instrument panel is occasionally dead, but not all of the time. I believe it must be a ground wire. (At least I'm hoping!) So where is the ground wire to the panel.... Thanks.
Ken in WV
Old Aug 26, 2017 | 6:03 PM
kevinkpk's Avatar
Probably in the connector. If you can, (my suggestion) pull the connectors apart, and with di-electric electrical cleaner, spry the contacts on the connection points
Old Aug 28, 2017 | 11:52 AM
hicksvilleshick's Avatar
In our suburban I tapped into the ground wires for the cluster and grounded it to metal behind the cluster. Iirc, there were 2 ground wires for it, and I ran better grounds for both.
