Help rough idle possible vacuum leak
Old Jan 7, 2023 | 2:03 PM
02shortbed's Avatar
Default Help rough idle possible vacuum leak
changed out my spider injector on my 02 silverado now I'm getting a rough idle. i double checked everything and everything is connected as it should be. i used carb cleaner to clean out all the carbon build up. could that be the issue? Also when i put on the intake on the spider it was hard to put on so i tried my best to shove it and used the bolts to tighten them up could that have been a factor since it didnt seal properly?
Or could i have not created a good enough seal? Some air connections where only connected with silicone so im not sure if thats a factor or not. Any help would be great. 02 silverado 4.3 v6 2wd Also if i hit the gas pedal slowly the check engine light flashes 1 or 2 or 3 times.
i just checked with carb cleaner sprayed all around and no change in idle. Im stuck. Any help would be much appreciated
Greybomber90
Jan 5, 2016 10:44 PM
Fishinfooleric10@aol.com
Sep 23, 2013 6:42 PM
clintsy
Aug 18, 2012 7:29 PM
phil03
Dec 5, 2010 12:25 PM
projbelair
Jun 19, 2009 5:55 PM
