Low oil pressure
Old Nov 4, 2024 | 10:52 PM
Goto661's Avatar
Default Low oil pressure
I have a 1999 gmc sierra that I picked up last week with low pressure. 20psi cold and 3-5 hot idle confirmed with a manual gauge. I changed oil pump pickup tube o ring thinking that was possibly the problem but no luck. Fired it up and it was the same as before maybe a few pounds better but not much. I was worried I possibly pinched the o ring or it wasn’t seated completely so i put 10quarts of oil in the engine and jacked up the rear significantly to try and submerge the o ring and pickup tube to rule it out. Same result no change in oil pressure at all. Should I add more oil as the pickup tube might not be completely submerged yet or and I looking at bigger internal issues somewhere in this engine more than likely down the road. 5.3 vortec, runs great and is extremely quiet. Thank you guys
Old Nov 5, 2024 | 12:24 AM
jfmorris's Avatar
My Haynes manual says that you should be seeing 6psi at 1000rpm, 18psi at 2000rpm and 24psi at 4000rpm with a mechanical oil pressure gauge.
You say you changed the pickup tube o-ring? What about the oil pump itself? They say the main reasons for low oil pressure are:
1. Work out oil pump.
2. Bad bearings (need a rebuild?).
Old Nov 6, 2024 | 8:53 PM
Goto661's Avatar
I did not change the oil pump or anything else. I was wondering if everyone thought that 10 quarts would be enough to cover the pickup oring to rule that out. Like I said I jacked the rear of the truck up significantly and there was no change. I’ve also been reading about cam bearings possibly being a cause as well
Old Nov 6, 2024 | 9:06 PM
jfmorris's Avatar
Well... changing the oil pump for a new one would be a lot easier than doing the bearings! I think I recall from looking at the manual yesterday, that you access it through the timing chain cover.
Sal Briseño
Jan 28, 2026 10:02 AM
mac_in_mt
Apr 28, 2022 3:19 AM
Shannon43
May 18, 2012 10:53 AM
jake63
Nov 13, 2011 1:14 AM
kwilson1
May 22, 2006 2:58 AM
