Low Oil Pressure light keeps coming on
Old Nov 4, 2024 | 4:52 PM
ItsClay's Avatar
Default Low Oil Pressure light keeps coming on
I have made an account here in hopes somebody can help. I have a 2003 Chevrolet 1500 5.3L and it has an oil pressure issue that I can’t figure out. Driving it rides at 20psi and at idle it drops below 5psi causing the light and dinger to go off. I have replaced the oil pump twice, the oil pressure sensor, Cam and Main bearings, as well as the dash cluster thinking maybe it was the gauge itself. I’m at a lost any suggestions are appreciated.
Old Nov 4, 2024 | 7:37 PM
Rednucleus's Avatar
Welcome to Chevy. Are you burning oil - if so how many miles per quart. And how many miles on the motor and what weight oil are you using.
Old Nov 5, 2024 | 12:25 AM
jfmorris's Avatar
Have you checked it with a mechanical oil pressure gauge?
Old Nov 5, 2024 | 1:46 AM
ItsClay's Avatar
I have checked it with a mechanical gauge and it shows the same as the dash. It doesn’t burn to much oil as far as I can tell, I don’t drive it much I have a second vehicle I drive. I run 10w-30.
Old Nov 5, 2024 | 9:50 AM
Rednucleus's Avatar
How many miles? I have a 93 Sub with over 350k: I need to run 20-50 to keep the pressure up and the light off. Maybe try 10-40 next change
Old Nov 5, 2024 | 10:07 AM
ItsClay's Avatar
I can definitely give that a shot. It’s got 250k miles.
Sal Briseño
Jan 28, 2026 10:02 AM
ashort
Jun 17, 2021 8:06 AM
Firemen175
2007 - 2013 (GMT900)
Apr 15, 2019 12:32 AM
5inhisgrip5
Astro
Feb 20, 2016 9:45 AM
Shannon43
May 18, 2012 10:53 AM
