Master Switch Problems...
Old May 26, 2018 | 2:31 PM
SilveradoFreak's Avatar
Default Master Switch Problems...
Recently, I bought a 2004 Silverado Z71. The only problem with it was “intermittent problems with the driverside windows and locks after it rains.” Come to find out, it doesn’t work, at all. I took the whole thing out and cleaned up the circuit boards but it still doesn’t work. As far as I know/can see, there aren’t any blown fuses. Is it even plausible that wires are the source of nothing working, or have I ruled out pretty much everything and have to replace the master switch?
Old May 28, 2018 | 12:08 AM
hicksvilleshick's Avatar
I'd get a new switch.
I'm facing the same thing, my mirror switch has kind of died, my drivers side window switch acts up when it's wet out, it won't cancel the auto-roll down.
I want to say that when I priced them they were in the 30-50$ range.
You can get used ones on the ebay a little cheaper.
Old May 28, 2018 | 1:07 PM
Check the switch with a meter before buying a new one. Also see if power is getting to the motor.
