mystery dying
Old Apr 1, 2020 | 5:26 PM
01k254wh's Avatar
Angry mystery dying
Got an 01 K2500 with a 6.0L, run the truck at idle in the driveway for about 25 to 30 minutes, the truck dies and won't restart. Let it set for 25 to 45 minutes and it restarts and runs fine.
thought it might be the ECM, got a remanufactured one from flagship1. Plug n play loaded with all required files based on my VIN. Enstalled it completed the passlock relearn procedure,
vehicle started and ran fine for two days. died again today (04-01-2020). Waited for a tow truck for 45 minutes just before he arrived the truck started and ran fine.
After it dies and won't start the fuel pump does come on when the key is turned to the on position. Any one having this issue, or any ideas where to start
Old Apr 1, 2020 | 8:14 PM
put a fuel pressure gauge on it
Old Apr 1, 2020 | 8:56 PM
Rednucleus's Avatar
Sounds like something electronic is getting hot and failing, then happy again once cooled down. Any codes/CEL?
Old Apr 3, 2020 | 8:51 AM
+1 to check codes and fuel pressure.
test when the fault is active.
-check for rpm signal with a scan tool
-check for spark
-check fuel pressure
Old Apr 6, 2020 | 10:45 AM
01k254wh's Avatar
no codes before or after fail
Old Apr 6, 2020 | 10:47 AM
01k254wh's Avatar
will check tomorrow (04/07/2020) and let you know. Thanks
Old Apr 26, 2020 | 5:55 PM
01k254wh's Avatar
Ok had to wait and get a scanner. Checked RPM after dying had no RPM reading. Changed the Crank Sensor out, truck started and is so far running ok. Thanks for the advise
Jsluss07
1988 - 1998 (GMT400)
Mar 6, 2020 7:32 AM
Tsmylie78
Oct 29, 2015 10:33 PM
zack3439
Camaro
14
Jul 28, 2015 7:25 AM
kirks22m
Apr 18, 2014 12:22 PM
kit141a
Mar 10, 2014 10:12 AM
