Need help with 2000 Silverardo
Old Apr 10, 2022 | 4:37 PM
Carsonmartinez's Avatar
Default Need help with 2000 Silverardo
I have a 2000 Silverado with the 5.3 and it has a few problems that I have been trying to work on for a while with no success. It has no fuel gauge after replacing pump, and the temperature gauge does not work either. It has 3 lights on the message center for security, battery and low fuel constantly cycling between the 3. The obd2 port powers up the scan tool but does not communicate. Any advice would be appreciated, thanks in advance.
Old Apr 10, 2022 | 4:44 PM
hanky's Avatar
If,,,,,,,,,,the problems started showing up after the fuel pump assy was replaced, it may be time to recheck the work done.
Always a good first move to check all the fuses for an open fuse. If one is found , that system needs to be thoroughly checked out to determine why the fuse is opening.
Old Apr 11, 2022 | 7:14 AM
It was like that before changing the pump, I’m pretty sure I have checked all of them but I’ll double check again. Any specific fuses I should check first?
Old Apr 13, 2022 | 7:36 PM
Suburado5.34L60E's Avatar
That would mean it's time for a new gauge cluster, I've owI'd my 03 suburban for 3 years and have gone through three of them, had an 05 Silverado for a year replaced it once, had an 03 Silverado replaced it twice. Fact of the matter, they go out constantly and it's a common problem, I always go to the junk yards and find working ones because they typically only charge 20-30 bucks so i can buy 3-4 for the price of one remaned one. Nothing wrong with anything else you have I guarantee it.
Old Apr 16, 2022 | 7:16 PM
I have already replaced my cluster once and it didn’t fix anything, any other ideas what could be causing it? My battery also drains very fast and I know my alternator is good
Old Apr 16, 2022 | 7:29 PM
My horn fuse also is always blown and if I replace it it will blow after 1-2 seconds on the horn not sure if that has anything to do it, just thought I’d throw this out there too.
Old Apr 19, 2022 | 10:14 AM
I finally found the problem, splice pack 205 was missing the cap. Everything works now except for a few other stuff that’s not related. Hope if anyone else is having this problem this helps
Puffy Clouds
Jul 13, 2019 11:30 PM
Rmps1
Apr 10, 2019 1:57 AM
Horseman
Apr 24, 2017 6:11 AM
BillyS
Feb 12, 2012 10:19 AM
Clearvu1
Oct 21, 2008 10:28 AM
