Need some help
Old Jun 8, 2021 | 12:02 AM
M16oneklip's Avatar
Default Need some help
When this code came up I changed out the o2 sensor
After I replace the o2 sensor then this code came up. Need some help.
Old Jun 8, 2021 | 6:10 PM
chem_man's Avatar
15 Year Member
Check the wiring to the O2 sensor. There might be a broken wire at the connector or somewhere between the PCM and the O2 sensor. If you do not find anything amiss, remove the new O2 sensor and install it on the other side to see if the sensor itself is bad.
Remember, a DTC tells you that there is a problem with a system or circuit. It does not indicate that a given part is bad, hence some diagnostic work needs to be performed.
Old Jun 8, 2021 | 8:27 PM
M16oneklip's Avatar
Right on man thanks for the info, I’ll check that out.
Steverenio
Nov 25, 2017 4:03 PM
Brian99_03
Feb 20, 2013 8:29 PM
thomis
Oct 23, 2012 4:12 PM
Spiffy
Aug 13, 2012 6:41 PM
gribble
Sep 14, 2010 6:41 AM
