Oil Leak
Old Aug 29, 2019 | 6:09 PM
Stanley Fink's Avatar
Default Oil Leak
My truck started leaking oil today and not very slow. I’m thinking rear main seal.
Leaked a quart in about 5 miles. Oil pressure doesn’t go over 20.
Old Aug 30, 2019 | 11:54 AM
oilcanhenry's Avatar
Yeah, sounds like a rear crank seal to me too. 20 PSI is too low above idle. If you drive it at all, the old trick is to reduce any crankcase pressure by leaving the oil cap off, until you can repair it, or have it done. At a quart every 5 miles none of those seal swelling chemicals will work.Might as well change the oil pump too with the oil pan off.
Old Aug 31, 2019 | 8:50 AM
Thanks. You have a ballpark of what that might cost?
Old Aug 31, 2019 | 7:35 PM
The parts are cheap. $18 bucks for the rear main seal. A high volume oil pump (18 percent more pressure) is about $55 -140 dollars. Its the labor that will take time if you use a shop. I use an independent shop for things that need a hoist or a pit, Get 10 percent off labor with a AAA card too. Might look on Yelp for reviews if you use a shop to do the work..
RepairPal. com has a pretty good listing of what the going rates are in your area.Usually cheaper in smaller towns, then in larger cities.Of course dealerships will cost more, but that's just the name of the game.
Old Sep 5, 2019 | 5:48 PM
Thanks everybody. Turns out it was the oil sending unit. That also explained the low oil pressure. It was pushing oil right up through the plug.
Old Sep 5, 2019 | 8:15 PM
Its always a good thing when fortune smiles upon us!!!! Very glad to hear it turned out for the best Stanley!
joeincharlotte
Sep 16, 2014 11:30 AM
BurbanMCS
Apr 20, 2013 12:38 AM
aeropatr82
10
Apr 18, 2012 7:24 PM
ChevyChic
Oct 4, 2009 12:04 AM
DEEP
Astro
May 23, 2008 10:30 PM
