Oil leaking
Old Oct 2, 2020 | 10:23 PM
IrmoRabbidMoose's Avatar
Default Oil leaking
Hey guys!
the past month I’ve noticed oil dripping from my oil pan, bell housing, starter bolts and a little on the oil filter. About two weeks ago I changed my oil pan gasket thinking that was the culprit along with my pickup tube o ring. Didn’t solve it. Then, a couple days ago, after reading several articles and threads about several suspected areas I decided to change my valley pan gasket, intake manifold gasket, valve cover gasket and the oil sending unit. The back, top part of the motor was a little wet so I knew I had solved it. However, those same spots still have oil on them. At one point I had suspected the rear main, but when I removed the dust covers and the inspection port, the flywheel is dry as a bone. I’m a little lost at this point. I know someone out there has gone through the same thing I am. Can anyone help or point me in the right direction? I don’t wanna believe it’s my rear main but I’m starting to believe that could be it. Any help is appreciated!!
Old Oct 3, 2020 | 1:51 AM
oil cooler lines?
Old Oct 3, 2020 | 6:01 AM
oil cooler lines?
they all seem to be dry from where I’ve run my flashlight
Old Oct 4, 2020 | 7:59 AM
Bump!
KeithKman
Jan 13, 2019 5:44 PM
Jon-Erik Peterson
Oct 10, 2018 12:05 AM
deziking
Dec 28, 2012 10:06 AM
KGJC616
Jul 10, 2012 4:03 PM
cleft_asunder
Oct 17, 2009 11:36 AM
