Oil filter Adapter is Leaking
Old Apr 13, 2010 | 10:58 PM
KGJC616's Avatar
Unhappy Oil filter Adapter is Leaking
ok just last week i droped my oil pan to stop it from leaking near the back of the pan. i got it back up the other day and i put oil in the engine and when i went to start it i noticed that my oil filter adapter is leaking. its leaking on the top side of the adapter that meets the block.
I have a 1989 Chevy Silverado C2500 350 5.7L
when i droped the oil pan i droped the oil filter adapter and noticed there was a gasket there so i replaced it with a new gasket. it looked like it was a paper one so im not sure if that is the problem or not but any help would be greatly appreciated. thanks
Old Apr 14, 2010 | 3:22 AM
mudmaniac's Avatar
Ride of the Month
May 2009
Add a little silicon to the gasket and you should be good, make sure the surfaces are clean.
Old Apr 16, 2010 | 12:24 PM
KGJC616's Avatar
thanks for the info i put some RTV on it ill post later if it worked or not.
Old Jul 10, 2012 | 2:15 PM
victoria galindo's Avatar
New User
Awaiting E-mail Confirmation
i replaced oil filter adapter gasket , a few days ago but it dtarted leaking again
Old Jul 10, 2012 | 4:03 PM
Top-truck85's Avatar
Question
Originally Posted by victoria galindo
i replaced oil filter adapter gasket , a few days ago but it started leaking again
NAPA sells a kit for all the O-rings & gaskets that are associated with the oil filter adapter. Assuming you are talking about the adapter that provides the outlets for the oil cooler. there is a large, thick O-ring that goes up inside that adapter.
Currently, I am having issues with the oil filter gasket blowing out. Does anyone know what is causing this? After each replacement, I can run the truck as long as I want but after it cools and I run it the second time, the oil filter seal starts leaking and I have an oil cooler too. I have a high flow oil pump in a remanufactured block I purchased from JEGS. What could be the problem? Someone said a valve could be sticking? What does that mean. Are they talking about a intake or exhaust valve? I have rebuilt steel heads on the engine as well. it has about 1000 miles on it now. Please offer some suggestions!
klturi421
Jun 7, 2012 3:05 PM
ajizzle_84
Aug 17, 2011 6:41 AM
burbandad
Dec 19, 2010 12:11 AM
lukemoore646
May 31, 2009 5:19 PM
scoony
Dec 31, 2008 1:21 PM
