P0102maf
Old Mar 23, 2021 | 10:10 PM
Rich Quezada's Avatar
Default P0102maf
Got the cel replaced the MAF. The light went off. Drove around about 10 minutes stopped and started it back up and it went on. What should I check
Old Mar 23, 2021 | 11:37 PM
what chassis size, engine and model year
Old Mar 24, 2021 | 10:44 AM
2500hd-6.0-2006
Old Mar 24, 2021 | 9:40 PM
1. Verify the Mass Air Flow (MAF) ground by adding a ground to it...wire colour...black/white tracer. If it is the same, backprobe the Pink wire with a voltmeter to see if has battery voltage when the code sets.
2. If OK, switch the meter to the AC scale and check the Pink wire, there should be less than 0.2 volts of AC voltage. If higher, disconnect the alternator and retest, if now OK, replace the alternator.
3. If the power and ground were OK and there was no AC voltage, check the Hertz (HZ) on the Yellow wire, with it disconnected it should be 5 volts and no HZ, connected should be about 2600 HZ at 575 RPM and 3000 HZ at 900 RPM. The voltage will pull down to about 4 volts. If all OK, it has Powertrain Control Module (PCM) problem, verify good power and grounds to PCM.
Mike_axle
Apr 26, 2020 11:24 AM
andrewmorano
Sep 9, 2019 10:19 AM
zombiebanana88
Sep 15, 2013 5:13 PM
spyroe
May 15, 2013 1:03 AM
dreadinger
Aug 2, 2010 7:17 AM
